How to Troubleshoot Connector Problems with PowerTools
View Connections and Content Sources
Your various connections and content sources can be found in the Connectivity Hub PowerTools page.
- Navigate to Tools > Power Tools.
- Here you can view a list of your Connections and Content sources.
View the Connection Settings
Some of the fields may vary depending on your connection/content source.
- Click on a connection, such as the Box Connection, and click Settings: - Click to see the settings that you specified in the Edit Web Service Connection page > Security tabs.
- Click Metadata to see the Metadata page and see any metadata associated with the selected connection:
- Click Users/Groups to see the Users/Groups page and see any user/group data that is associated with the selected connection. You can configure the following settings:- Max user/group count: Leave the default, 100, or change.
- Timeout (sec): Leave the default, 30, or change.
- Script to filter and highlight users/groups: Go to Scripts > Example scripts > User Scripts/Group Scripts.
- Get Users/Groups: Click this button to retrieve the specified users.
- Apply Filter: Click Apply Filter if you specify a script to filter and highlight users/groups.
- Click Members to see the Members page and any members data that is associated with the selected connection. You can configure the following settings:- Group identifier: This ID appears when you enter a Discovery group account in the Edit Web Service Connection > Security page.
- Max member user/group count: Specify the maximum number of users/groups that can be members of this group.
- Get Members: Click to see your members list.
If an error occurs, see the logging information:
View Your Content Settings
- Click on a content source, such as SharePoint Online Content, and click Settings to see the settings that you specified in the Edit Web Service Connection page > Security tabs.
- Click Crawl to see the Crawl page. You can configure the following settings- Data Store: Select the appropriate data store.
- Last Update: See the date of the last update and the type of operation that ran:- Crawl - Full
- Crawl - Incremental
- GetChanges
- Page Size: Leave the default, 20000, or change.
- Timeout: Leave the default, 30, or change.
- Script to filter and highlight items.
- Start Crawl: Click to retrieve the content from the specified data store.
- Apply Filter: Click Apply Filter if you specify a script to filter and highlight items.
- Click Item Data to see the Item Data page. You can configure the following settings: - Crawl Url: Specify the URL to crawl for content.
- URL comes from crawl log or content test bench: Click if this statement is True.
- Get Metadata: Return the metadata for the item.
- Get Content: Return the item content.
