How to Automate Connection to the Configuration Database of Connectivity Hub
Script functionality is valid for this version of Connectivity Hub, but may not be available in future releases.
Procedure
To automate connection to the configuration database of Connectivity Hub, use the following procedure after installing Connectivity Hub:
Create a PowerShell script (ConnectToCHDB.ps1) file and copy/paste the following content into it:
DBConnectionScriptParam(
[Parameter(Mandatory=$true)]
[string]$User,
[string]$Password,
[Parameter()]
[string]$DBServer = $env:COMPUTERNAME,
[string]$DBName,
[Parameter()]
[string]$DBUser,
[Parameter()]
[string]$DBPassword
if ($DBUser -eq "" -or $DBUser -eq $null)
$DBAuthMode = "Service"}
else
$DBAuthMode = "Impersonate"}
$CHServer = "http://localhost:55001"
$baseAPIUrl = "$CHServer/api/databaseConnections/"$connectionRequest = "undefined?dbOperation=Connect"
$securePassword = ConvertTo-SecureString $Password -AsPlainText -force
$credential = New-Object -Typename System.Management.Automation.PSCredential -ArgumentList $User,$securePassword
$body = @{dbAuth=$DBAuthMode
type="ConfigurationDatabase" dbConnMode="Basic" displayConnectionString="" dbServer=$DBServer
dbName=$DBName
dbUser="" dbPass=""} | ConvertTo-Json
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Content-Length", $body.Length)
$headers.Add("Accept", "application/json, text/javascript, */*; q=0.01")
$headers.Add("Content-Type", "application/json")
$reqUrl = $baseAPIUrl+$connectionRequest
Write-Host "Connecting to $DBName database on $DBServer server..."$connectResult = Invoke-RestMethod -Method 'Post' -Uri $reqUrl -Credential $credential -Headers $headers -Body $body
# verify if database needs update
$reqUrl = "$CHServer/api/healthcheck/dbversion"
Write-Host "Check if database needs upgrade..."try {
Invoke-RestMethod -Method 'Get' -Uri $reqUrl -Credential $credential -Headers $headers
} catch {
# Dig into the exception to get the Response details.
Write-Host "StatusCode:" $_.Exception.Response.StatusCode.value__
Write-Host "StatusDescription:" $_.Exception.Response.StatusDescription
$exception = $_.ErrorDetails
if ($exception.Message.Contains("requires update"))
Write-Host "database needs upgrade..." $reqUrl = "$CHServer/api/DatabaseConnections?type=ConfigurationDatabase" Write-Host "Get config database..." $dbconfig = Invoke-RestMethod -Method 'Get' -Uri $reqUrl -Credential $credential -Headers $headers
$dbId = $dbconfig.id
$configJson = $dbconfig | ConvertTo-Json
$headers.Add("Content-Length", $configJson.Length)
$reqUrl = "$CHServer/api/DatabaseConnections/$dbId`?dbOperation=Upgrade" Write-Host "Update config database..." Write-Host "Calling $reqUrl" try {
Invoke-RestMethod -Method 'PUT' -Uri $reqUrl -Credential $credential -Headers $headers -Body $configJson
} catch {
Write-Host "ErrorDetails:" $_.ErrorDetails.Message
#get and update cache dbs
$reqUrl = "$CHServer/api/DatabaseConnections?type=CacheDatabase"
Write-Host "Getting all cache databases..." $cachedbs = Invoke-RestMethod -Method 'Get' -Uri $reqUrl -Credential $credential -Headers $headers
$count = $cachedbs.Length
Write-Host "Found $count cache databases..." Foreach($cachedb in $cachedbs)
$dbId = $cachedb.id
$configJson = $cachedb | ConvertTo-Json
$reqUrl = "$CHServer/api/DatabaseConnections/$dbId`?dbOperation=Upgrade" Write-Host "Update cache database: $dbId..." Write-Host "Calling $reqUrl" try {
} catch {
Write-Host "Installation completed" -ForegroundColor "green" -
Launch a PowerShell command line prompt as an Administrator.
- Navigate to the folder where the ps1 file was created.
- Execute the script by running the following command, and note:
- The DBServer parameter is optional.
- The default value is the local computer name.
- The
DBUserandDBPasswordparameters are optional, and can be specified to connect to the database using the Impersonate Authentication mode.
.\ConnectToCHDB.ps1 -User "Service_Account_Name" -Password "Service_Account_Password" -DBName "Configuration_Database" -DBServer "Database_Server_Name"
