View detailed information on admin and system actions
To improve visibility into user actions, Connectivity Hub has introduced functionality to automatically audit all customer-interacted controllers, allowing you to view detailed information regarding key user actions performed in Connectivity Hub. This means that any admin/user-initiated action through the UI or API, such as creating, updating, or deleting items, starting or stopping tasks, managing configurations, or interacting with connectors, is recorded in the audit log.
The audit log provides a complete view of user and system activity, supporting compliance, troubleshooting, and operational monitoring across the entire platform.
To view your admin action data, you can query the database or use a reporting tool, such as Grafana. For more information on how Grafana can connect to your Connectivity Hub database, see Grafana data sources in the Grafana documentation.
Prerequisites
To be able to view reports on administration actions, the following is required
Enabling admin action reporting
By default, the admin action reporting feature is disabled. To enable it, do the following:
  1. In the Connectivity Hub administration portal, click Tools > Configuration > Log Settings tab.
  2. In the Enable audit logging field, enable the checkbox to turn on the audit logging functionality.
Visualizing your user action data
Connectivity Hub can use a reporting tool, such as Grafana, to display your user action reports. The following steps show how you can connect Grafana to Connectivity Hub:
  1. Ensure that you have completed the prerequisites for Grafana integration.
  2. In Grafana, click Dashboards from the menu.
  3. Click New > Import. For more information, see Import dashboards in the Grafana documentation.
  4. Optionally, you can change the dashboard name, folder, or UID to your preference.
  5. Upload the following json file: "Connectivity Hub Audit Logs".
    • When you select the link above, right click the page, select Save as... and save the json file.
  6. Select the data source you created in the prerequisites.
  7. Click Import.
  8. Verify that your dashboard is receiving your Connectivity Hub data.
Overview of collected admin action data
The following table describes the audit log information for every admin action event that is captured by Connectivity Hub:
Property
ID This is the ID of the audit log request.
Action This is the method that was used by the request. Possible values for this column include POST, PUT, and DELETE.
OldValues
This is the model for the old values before the change was made by the admin.
NewValues This is the model for the new values after the change was made by the admin.
RequestPayload This is the entire payload that was sent from the browser to your database.
Differences This specifies every difference between the OldValues and NewValues columns, signifying everything that was changed by the admin.
ChangedBy This specifies who was the admin user who made the specific updates. If your environment supports anonymous access, this column will state Anonymous.
Description This provides a description of the action that was performed.
ApiRoute This specifies the API route that was called when the action was performed.
ChangedAt This provides the timestamp for when the action was performed.
