About the Deltek Vision Connector
Features
The Deltek Vision connector indexes content from Deltek Vision into your preferred search engine, surfacing it through BA Insight’s SmartHub to provide users with integrated search results.
- The source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle. retains the master information and the search index Contains data from your source system. Your search application instance (Elasticsearch, SharePoint Online, etc.) contains the search indexes. One search index per content source. has only a representation (pointers).
 - Works with content created and stored within Deltek Vision.
 - High throughput is critical to the success of the implementation, and the Deltek Vision connector indexes every desired item with a very high throughput.
 - Minimizes the impact on the source system, ensuring no impact to its performance.
 - Only surfaces the content that users are permitted to see.
Security
The Deltek Vision connector honors the security of the source system.
Limitations
- The Cloud version is not supported at this time and older versions have not been tested.
 - Any other versions are not supported at this time.
 - The Deltek Vision Connector supports crawl items for any information centers along with all of their metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub..
