About the FTP Target Connector
The FTP target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch. - (A Search application instance has one or more indexes) is used to push content from a specified content source Content Sources do the following: Receive data from the Source System via the Connection, Filter the data it receives, Provide the results to the Target, Define the specific search index that contains the content you wish to index (and later search). to a FTP Server. For each file from the specified content source, two files will be created on the FTP server, one that contains the binary data and one that contains the metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub. retrieved by the connector. This document is focused on Target specifics and does not cover generic or common steps.
