About the OpenText Content Manager (Trim) Connector
The OpenText Content Manager connector was formerly known as:
- HP TRIM
- HP Records Manager
- HP Content Manager
- Micro Focus Content Manager
Features
The OpenText Content Manager connector is an advanced plug-in connector for BA Insight Connector Framework or Connectivity Hub.
The connector enables you to index all content types from LL/RM while honoring security and returning item metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub..
This connector can scale to extreme levels and has been applied against customer systems of hundreds of millions of items.
There are flexible options for choosing and pre-filtering content for extraction as well as variable models for retrieving the files that allow for different scenarios.
This topic is focused on the specifics of the OpenText Content Manager connector and does not cover generic or common steps.
For more information, see the Connectivity Hub documentation.
Feature List
- Repositories/Object store
- Object Type
- Recursive/Hierarchical folder filter
- Custom query
Security
The BA Insight OpenText Content Manager connector honors the security of the source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle..
