About the ProjectWise connector
Overview
The Upland BA Insight ProjectWise connector allows you to index and crawl Bentley ProjectWise datasources and the physical files that are stored in the document management system. The connector can extract relevant metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub. from Bentley ProjectWise storage and return the full content of documents stored in ProjectWise.
Features
Note the following features with the ProjectWise connector:
Ability to index content included in ProjectWise datasource storage areas.
Ability to return a list of all users, groups, group members, and document metadata from ProjectWise datasources.
The expected metadata returned by the connector includes id, update time, file name, description, status, and file size.
Ability to index content from both flat sets and logical sets of documents.
Ability to use custom filters to add additional filtering to the enumeration query.
Prerequisites
Note the following prerequisites:
You must create a storage areas for your ProjectWise datasources.
You must use a ProjectWise account with access to the storage areas.
Limitations
Note the following limitations:
Security is not supported, everything is public
