About the SharePoint On-premise Connector
Features
BA Insight’s SharePoint On-premise Connector enables you to perform the following:
- Connect to SharePoint 2016, SharePoint 2019, and SharePoint Subscription Edition.
- Fetch data from any site, document library, or list, and index this content securely.
- Securely index both the full text and metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub. of documents in SharePoint into a search engine, enabling a single searchable result set across content from multiple repositories.
- This enables organizations to tap into the wealth of information accessible within multiple versions of SharePoint as well as other repositories and make that data instantly actionable to users through search.
For more information about the SharePoint connector's features and abilities, see https://www.bainsight.com/connectors/sharepoint-2016-connector/.
Limitations
- The default behavior of the SharePoint Connector is to not include 'hidden' properties in the metadata returned for the items. However, this can be customized by specifying a list of 'hidden' properties in web.config which should be returned.
- When versioning is enabled for files, the latest version of the file (be it published or unpublished) will be crawled, unless all versions are minor versions, in which case the entire file will not be crawled.
- File A (version 0.1) will not be crawled.
- File B (version 0.2) will not be crawled.
- File C (version 1.0) will be crawled.
- File D (version 1.1) will be crawled.
- File E (version 2.0) will be crawled.
- When a file has the "rejected" or "pending" status, it will not be crawled unless a previous version of the file already exists. If however a previous version exists (no matter its status), the file will be crawled.
- File A (version 1.0) with the status pending or rejected will not be crawled.
- File B (version 1.0) with the status approved will be crawled.
- File C (version 2.0) with the status pending or rejected will be crawled.
- File D (version 2.0) with the status approved will be crawled.
Security
The SharePoint On-premise connector honors the security found in SharePoint and provides both full and incremental crawls Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run..
