About the Jira Connector
The Jira connector is an enterprise grade indexing connector that enables issues stored in Jira to be crawled and indexed. This enables SharePoint, or any other portal, to serve as the single point from which users can search and retrieve the content they need from multiple content sources.
Security
The Jira Connector requires the BA Insight Advanced Security Module to honor the full security model defined in Jira.
Limitations
- The following permissions related changes needs a full crawl to properly update permissions in the search index.
- Reporter, Project Lead, Current Assignee, User Custom Field Value or Group Custom Field Value permissions were added / removed in the issue security scheme of a project.
- Project Lead permission is used in a security scheme, and project lead was changed.
- Restricted comments are not stored in the search index.
- Security trimming for Jira Server version 8.22 and above is not supported
