Azure Blob Connector Prerequisites
| Required Permission | Description |
| Azure | The installation user account must be able to register, configure, and grant Access for an Azure application. |
| Azure App Permissions |
The application configured for the connector must have the following Graph API permissions granted in Microsoft Azure: Note: The type for the following permissions must be "Application". Delegated permissions are not required.
| Azure Blob Storage |
Multiple Permissions The application configured for the connector must be granted the following permissions (otherwise use the "Single Role" detailed below):
This can be achieved by creating a custom role in Azure (see Microsoft documentation) and assigning it to your configured application. Single Role
| Windows | The account used to run the connector must be a local Administrator on the server and cannot be any of the built-in service accounts (NetworkService Local account used by the service control manager. Not recognized by the security subsystem, so you cannot specify its name in a call to the LookupAccountName function. Has minimum privileges on the local computer and acts as the computer on the network., local machine, etc.) |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
| Required Software |
IIS .NET Framework v4.7.2 |
ASP.Net must be enabled |
| Connectivity Hub Version | v2.2 or newer | Azure Blob Connector requires Connectivity Hub version 2.2 or newer in order for all features to work properly. |
