Box Connector Prerequisites
The prerequisites for the Box.com connector are specified below:
| Required Permission | Description |
| Box Account | Box.com administrative account (used to access Box while crawling) |
| Box Support |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
All BA Insight Connectors support fetch ACLs from the source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle.. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework or Connectivity Hub. |
| Required Software |
