Configure Egnyte Web Site IIS Certificate
  1. Open the IIS manager and confirm your Egnyte IIS site exists in the Sites list.
  2. Bind your web server certificate to the newly-created site:
    1. Locate the entry BA Insight Egnyte Connector site in the left-side pane.
    2. Right-click this site and select Edit Bindings from the sub-menu that appears.
    3. A new configuration windows opens.
      1. Port: Ensure that the Port (443) has been populated by the installer. See the graphic below.
    4. SSL certificate: Click the drop-down menu to select your previously installed certificate.
  3. If you are running on a specific hostname or multiple certificates on port 443 specify or select the following:
    1. Host name
    2. Require Server Name Indication
    3. SSL certificate
    4. Access to this example site would be "https://egnyte.domain.local"
  4. Click OK to complete the configuration process.
  5. Optional:
    • If the HTTP binding is no longer used, it can be removed.
    • Select the configuration binding and click "Remove."
