How to Configure Your Teams Connector Using Web.config
The following advanced configuration settings are available in appSettings section of web.config file.
| Key Name | Value Type | Description |
| GraphApiMessagesPageSize | Positive integer | The page size value to use in all Microsoft Graph API calls that enumerate channel messages. |
| GraphApiGetUsersPageSize | Positive integer | The page size value to use in all Microsoft Graph API calls that enumerate Azure AD An identity and access management solution from Microsoft that helps organizations secure and manage identities for hybrid and multicloud environments. users. |
GraphApiGetGroupsPageSize |
Positive integer | The page size value to use in all Microsoft Graph API calls that enumerate Azure AD A directory service for Windows domain networks. A hierarchical structure that stores information about objects on the network. Used to manage permissions and control access to critical network resources. groups. |
GraphApiDefaultPageSize |
Positive integer |
The page size value to use in all other Microsoft Graph API calls. |
| GraphAPITimeout | Positive integer | This specifies the timeout value, in seconds, for requesting Microsoft Graph API calls. |
| MaxRetriesValue | Positive integer |
Overwrites max value of retries in the Graph API request.
| GraphEntryPoint | String | This setting specifies the Graph entry point. By default, this value is set to https://graph.microsoft.com. |
| AuthorityEntryPoint | String | This setting specifies the authority entry point. By default, this value is set to https://login.microsoftonline.com. |
