Configure Your Web Server to Use High Trust Certificate
IIS Manager 8: Import the .pfx file into IIS
In IIS Manager, select the ServerName node in the tree view on the left.
Double-click the Server Certificates icon.
Select Import in the Actions pane on the right side.
In the Import Certificate dialog, use the browse button to browse to your .pfx file, and then enter the password of the certificate.
If you are using IIS Manager 8, there is a Select Certificate Store list. Select Personal. (This refers to the "personal" certificate storage of the computer, not the user.)
Ensure that Allow this certificate to be exported is enabled, and then select OK.
