Connections Connector Prerequisites
The prerequisites for the IBM Connections Connector are specified below:
Note: If you are installing a Web Services connector, such as the IBM Connections connector, on a different server than Connector Framework, make sure that you also follow the Connector Framework Installation Prerequisites.
| Required Permission | Description |
| Connections Account |
| Connections Support |
IBM Connections versions v3.0.1 and v4.5 |
| Searchable content types | Yes |
| Content Update | Full and Incremental |
| Permission Types | Yes |
| Required Software | Oracle 10+ database |
Install the required Connector Common API locally on either:
