Contentful Connector Troubleshooting
The Contentful Connector has a custom log in the Logs folders under the installation target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch.
- (A Search application instance has one or more indexes) location.
By default, the logging level is set to INFO.
If you want to troubleshoot, set the log level to DEBUGin the Logging.config file in the installation directory.
