Create and Configure Certificate
About the BA Insight Self-Signed Certificate Script
Use the script contained in the following zip file to create a self-signed certificate for use with BA Insight products: CreateSelfSignedCertificate.zip
Script Operating System Support
  • The script uses PowerShell API which is only available in Windows 10+ or Windows Server 2016+.
  • If the API is not available, you receive a corresponding error message when running the script.
  • It is possible to use a certificate generated in Windows 10 or Windows Server 2016 on a server running Windows Server 2012 or older versions of Windows.
Script Parameters
The script supports the following parameters:
Parameter Type Description
CertFriendlyNam String
Friendly name for the generated certificate. This value is used several times by the script:
Example value: "BA Insight Self-Signed Certificate"
IssuedTo String
Name of the server the certificate will be installed to.
The "issuedTo" has Multiple Options:
  1. This value is used in Issued To and Dns Name metadata of the generated certificate.
    1. Example Value: "myserver.mydomain.local" representing the name of the server
  2. Use the final Web Site Host Name
    1. Example Value: bainsightadd.mydomain.local
    2. In this example a DNS entry would require creation point to the server IP Address
    3. Alternatively a Host.ini record on the Server can be added in place of the DNS entry.  Any client trying to access the Site would require a host.ini entry also
Example value: "myserver.mydomain.local"
How to Create a Self-Signed Certificate
The steps below describe how to use the BA Insight script to generate a self-signed certificate:
  1. Download the script.
  2. Extract the script file from the ZIP archive.
  3. Start a PowerShell window as an Administrator.
    Note! It's important to run the script as an Administrator.
  4. Navigate to the folder where the script is located by executing the following command in the PowerShell window:
    cd "path_to_the_folder"
  5. Run the script by executing the following command in the PowerShell window:
    .\CreateSelfSignedCertificate.ps1 -CertFriendlyName "certificate_friendly_name" -IssuedTo "server_name"
  6. When prompted, enter the password to be used as the key for the PFX file.
  7. Sample script output is displayed in the screenshot below.
    1. Copy the value listed under Subject from the script output for future reference:
  8. After the script is finished, two files (CER and PFX) are output to the local directory where the script itself is stored.
    These files are two different representations of the generated certificate:
  • CER file:
    • Contains only the public key of the certificate and may be shared without any restrictions.
  • PFX file:
    • Contains both public and private keys and is secured with the password provided during the script execution.
    • The PFX file must be securely stored.
Note! Expiration time for certificate generated by the script is set to 100 years from the time the certificate is created.
Important: The user account running the Microsoft Teams Connector application pool, must have READ access to the Trusted Root Certificate store on the local machine.
This user account cannot beNetworkService Local account used by the service control manager. Not recognized by the security subsystem, so you cannot specify its name in a call to the LookupAccountName function. Has minimum privileges on the local computer and acts as the computer on the network..
