Documentum Connector v2 Prerequisites
| Required Permission | Description |
| Documentum User account | A valid Documentum account with READ access to all documents. |
| Documentum version | Minimum version: v6 | EMC Documentum Connector supports all Documentum versions from v6 up. Connects to Documentum DFC via DFC. |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run., unless noted. |
| Permission Types | Yes | All BA Insight Connectors support fetch ACLs from the source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle.. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework |
| Required Software |
You must install one of the following Java instances before you run the connector installation (.msi file), or your installation could fail.
