How to Set Up and Configure Documentum v2
Documentum Account:
Specify a login user name and password that is a valid Documentum account.
This account must have read permissions to all documents in order to crawl.
Comma (,) separated list of metadata which is NOT retrieved for indexed documents.
EnterTimeZone Offset:
If your Documentum deployment stores dates with the local time zone instead of UTC, please specify the time zone of your Documentum deployment.
This typically only apply to Documentum pre-v6 (or upgraded to v6 or higher).
Server Address and Port:
Enter the EMC Documentum server address and docbroker port using the following format:
myserver:port (Example: 172.16.10.00:1490)
Typical port values include:
1489 – Native
1490 – Secure
Exclude UTC date field marker:
Older versions of Documentum fail to interpret the UTC marker in DQL queries.
To build DQL queries without the UTC marker please select this option (from version D6 onward dated are stored in UTC by default)
Content Configuration Specifics
The EMC Documentum Connector provides settings that you can use to specify which documents to crawl and what information to retrieve about each of these documents.
These settings must be specified in an XML file.
All of the elements are optional.
For this reason, if a setting is not defined, the default value is used.
| Setting | Default Value | Description |
| <Customfilter> | Empty (no filter) |
If you do not want to crawl all of the documents, you can specify a DQL query fragment to filter items using any type of metadata.
| <indexAllVersions> | (Only latest version of the item will be indexed) | Set to "True" if you want to index all versions of a specific document as separate entries |
| <saveevent> |
The EMC Documentum Connector uses the audit table to get events that signal document changes.
| <deleteevent> | dm_destroy |
The EMC Documentum Connector uses the audit table to get events about deleted documents.
| <rootObject> | dm_document |
Defines the root object type included in a crawl. Higher level types in the type hierarchy are skipped.
| <enableContentless> | True | If this settings is set to "True," documents without any content are crawled |
| <contentlessExtension> | unk |
This setting contains the extension that is returned for documents that have no content.
| <downloadBlockedExtension> | Empty (No extensions) |
You can define a comma-separated (,) list of extensions.
| <includeFolderPath> | False | If set to "True" the folder path (r_folder_path) is retrieved if it is part of the item's metadata. |
| <includeCabinetName> | False |
| <disableSavedCheck> | False |
If this option is set to "True", document saved events are not checked on incremental crawls Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run. to report modified documents.
| <disableDeletedCheck> | False |
If this option is set to "True", deleted documents are not checked on incremental crawls to report modified documents.
| <dontRetrieveDocument> | False |
If set to "True", no content is returned for any of the documents. Only metadata is returned. For example: <dontRetrieveDocument>True</dontRetrieveDocument> |
| <dontRetrieveSecurity> | False |
If set to "True," permissions are returned for any documents.
| <IncludeParentId> | False |
If set to "True", the parent ID is returned as metadata.
| <skipCrawlReadPermissionCheck> | False | Set to "True" if you want to index documents that the crawl account does not have at least READ access permissions to (that is, the account has only Browse permissions). |
| <enableCustomFilterOnGetItem> | True |
If set to "False", the custom filter is not applied on the GET item calls:
Deprecated Configuration Options
| <additionalChanges> | 'Effective' and dsm_doc_classification='For Internal Use Only' and acl_name like 'd2%' and dsm_doc_collection_key in (select distinct(alias_name) from dm_alias_set where object_name='dsm_es_publishfiuo') | |
| <enableFilterOptimization> | True |
Upgrading Documentum
If you upgrade your Documentum from version 2 to version 3, you must create a new Connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) and Content Source Content Sources do the following: Receive data from the Source System via the Connection, Filter the data it receives, Provide the results to the Target, Define the specific search index that contains the content you wish to index (and later search)..
Your Connection and Content Source do not carry over from the old version.
