Documentum Connector Troubleshooting
The EMC Documentum Connector has a custom log in the Logs folders under the installation target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch. - (A Search application instance has one or more indexes) location.
The EMC Documentum Connector has also logs for the Java component of the connector.
The logs are located under the installation location.
Default Installation Location: C:\Program Files\BA-Insight\BA-Insight Documentum Connector\Documentum Windows Service\Bin\Log
The log level for Java Service logs can be changed from DocumentumService.conf.
