Egnyte connector release notes
Egnyte connector 1.1.0.0
System Enhancements
| Feature | Description |
| Connector performance enhancements | The Egnyte connector has been enhanced to reduce the number of API calls that are made during security syncs Loads User and Group tables and executes the mapping based on the connector configuration., improving the overall performance and efficiency of the connector. |
Fixed issues
Users that were deactivated in the Egnyte source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle. were still displaying in the Egnyte connectors user mappings after a security sync. (BAI-17389)
Adding a slash to the end of a folder path when specifying excluded folders in the Egnyte connector configuration would cause the exclusion to fail. (BAI-17280)
Specifying a value for included folders in the Egnyte connector configuration would cause Test Bench and crawl jobs to fail. (BAI-17274)
