File Share Connector Prerequisites
The following table details the permissions required to use the File Share connector:
| Required Permission | Description |
| Trusted Domain |
Connector supports indexing file shares from the same domain as Connector Framework or Connectivity Hub with full security trimming. |
| Non-Trusted Domain |
From non-trusted domains without security. |
| Security |
Custom security can be set within the Connector Framework or Connectivity Hub based on business rules.
| SMB Support | Connector supports the same version of SMB as Windows, including v2 and v3. |
| Searchable Content Types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | The content must be secured via Active Directory domain users and groups |
| Required Software |
.NET Framework v4.7.2 |
Nasuni Cache Requirements
The BA Insight Nasuni connector must crawl the content from an isolated Nasuni instance to avoid disrupting the caching policy in place for end users.
Therefore, the following is required:
Must set up a dedicated Nasuni virtual appliance on-site
Virtual appliance must be configured as follows:
To use its own caching policy.
Virtual appliance does not require caching on-premise.
Set this value to as close to 0 as possible.
SMB protocol must be enabled on the virtual appliance.
Content to be crawled must be exposed via the SMB protocol.
