Foundation Connector Troubleshooting
The Foundation Connector has a custom log in the Logsfolders under the installation target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch.
- (A Search application instance has one or more indexes) location.
By default, the logging level is set to INFO. If you want to troubleshoot, set the log level to DEBUG in the Logging.config file in the installation directory.
Problem: Dataset Mapping is skipped for an item
The following message is found in the logs when trying to index an item "- parameter empty"
Solution
This message means that not all parameters mentioned in the Dataset Connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) info had a value in the SQL connector. All the Properties mentioned in the Dataset Connection info must have a valid value. If some items only have one single Property value that can be mapped, it is recommended to create and map an additional dataset using only those properties.
