Google Drive Connector Troubleshooting
The Google Drive connector has a custom log in the Logs folders under the installation target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch.
- (A Search application instance has one or more indexes) location.
By default, the logging level is set to
INFO. -
If you want to troubleshoot, set the log level to
DEBUGin the Logging.config file in the installation directory.
