Media Management Connector Prerequisites
| Required Permission | Description |
| Media Management User Account | You must have a Media Management user account with full READ permissions on all the content to be crawled from the Media Management repository through the OpenText API. |
| Version | 6.5 |
| Searchable content types | Yes | The Media Management connector enables you to connect to a Media Management source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle. and crawl the assets stored there. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | No |
The connector returns all content as public If you wish to restrict content to specific audiences, you can use the security scripting functionalities present in your connector framework: Connector Framework or Connectivity Hub. |
| Required Software |
