OpenText Content Manager (Trim) Connector Prerequisites
| Required Permission | Description |
| Domain User Account | A user account with READ access to all of the content on the file share. |
| Database User Account | A user account with READ access to all of the databases to be crawled. |
| Content Manager |
| Security Models |
You must understand how security is implemented within the OpenText Content Manager (Trim) connector and what model is used:
| Content Manager version |
HP Trim: v6.5 or higher |
| Searchable content types | Yes | All content. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
All BA Insight Connectors support fetch ACLs from the source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle.. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework or Connectivity Hub. |
| Required Software |
Before you install the OpenText Content Manager (Trim) Connector, you must install Connector Framework or Connectivity Hub. |
Recommended Changes to the Database
The following tables are missing the indexes that this Connector uses.
To improve the performance and reduce the load on the Trim Database server, you must create standard non-unique indexes on these tables and fields.
- Table: TSEXFIELD
- Index: exFieldFormat
- Table: TSEXFIELDV
- Index: evFieldURI
- Index: evObjectURI
- Table: TSNOTES
- Index: ntTableUri
