NdMirror Prerequisites
| Required Permission | Description |
| NetDocuments connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) string | The connection string used to connect to your ndMirror SQL server instance must have full READ permissions to all of the content to be indexed from the ndMirror repository. |
| NetDocuments version |
One installation per NetDocuments tenancy. |
| ndMirror version | 1.9 | ndMirror 1.9 must be downloaded, configured, and installed on your server. |
| Searchable content types | Yes | The NetDocuments connector enables you to connect to NetDocuments source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle., fetch data from any cabinet and index this content securely. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework. |
| Required Software | .NET Framework v4.7.2 | One installation per NetDocuments tenancy. |
