NetDocuments Connector Prerequisites
| Required Permission | Description |
| NetDocuments User Account | The account used to crawl your items must have full READ permissions to all of the content to be indexed from the NetDocuments repository. |
| NetDocuments version |
One installation per NetDocuments tenancy. |
| Searchable content types | Yes | The NetDocuments connector enables you to connect to NetDocuments source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle., fetch data from any cabinet and index this content securely. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
All BA Insight Connectors support fetch ACLs from the source system. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework. |
| Required Software | .NET Framework v4.7.2 | One installation per NetDocuments tenancy. |
