OneDrive Connector Prerequisites
Features |
Supported |
Additional Information |
| Version | O365 | Cloud-based |
| Searchable Content Types | Yes |
The One Drive connector enables:
By default the connector omits some system level properties typically not needed for indexing purpose.
| Content Update | Full and Incremental | All BA Insight Connectors support bothFullandIncrementalcrawls, unless noted. |
| Permission Types | Yes |
| Required Software |
.NET Framework v4.7.2 SharePoint Azure App Certificate |
A Active Directory A directory service for Windows domain networks. A hierarchical structure that stores information about objects on the network. Used to manage permissions and control access to critical network resources. Azure App must be registered with Azure and must have permissions as described in the table below. Certificate Details:
Required Permission |
Description |
| Azure |
You must have access to the Azure Portal site and permission tocreate and manage Azure app registrations. |
| Azure App permissions |
The OneDrive connector supports both authentication mechanisms: The permissions required for each mechanism is detailed below.
| Windows |
The account used to run the connector:
| Recommendations: Loading Users and Groups |
Non-Supported Features
The Connector does not have the ability to remove items from the Index when List folders are deleted.
It is recommended to run a Full Crawl periodically to remove these items.
All other delete functions are supported.
