SQL Connector Prerequisites
Note! The BA Insight SQL connector is embedded into Connectivity Hub and Connector Framework.
The connector requires only the following user account and application prerequisites:
Administrator Prerequisites
This section assumes the reader has considerable knowledge and experience in the configuration and administration of the following:
- Your database(s)
- Strong SQL knowledge and schema knowledge of the database(s)
| Required Permission | Description |
| Database Application |
| Azure AD An identity and access management solution from Microsoft that helps organizations secure and manage identities for hybrid and multicloud environments. Authentication |
| Azure AD Users and Groups | If Azure AD users and groups are used to secure database records, contact BA Insight to confirm your environment is compatible. |
| Application version |
| Searchable content types | Yes | All types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes |
| Required Software | .NET Framework v4.7.2 |
