Salesforce connector release notes
Salesforce 1.8.1.0
System enhancements
There are no system enhancements in this release.
Fixed issues
The following issues have been fixed in this release:
When running a security sync job Loads User and Group tables and executes the mapping based on the connector configuration. with the Salesforce connector, the security sync Loads User and Group tables and executes the mapping based on the connector configuration. was failing.
When setting up the Salesforce connector using Connectivity Hub quick mode, the quick mode jobs were failing.
The NewtonSoft.Json.dll and System.Net.Http.Formatting.dll libraries were absent from the Salesforce connector.
Salesforce 1.8.0.0
System enhancements
Fixed issues
If you configured the Salesforce connector with a valid password, then changed the configuration to an invalid password, the connector would use the cached valid password to perform tasks. (BAI-17367)
In some scenarios, SOQL queries would cause field names to not appear in the metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub.. (BAI-17248)
Incremental crawls Scanning and capturing only new data from all of your content sources. This data did not exist when the last crawl was run. were not correctly reporting changes to Salesforce security. (BAI-17149)
Salesforce attachments were not being crawled when using a custom SOQL query. (BAI-16588)
Users were not loading correctly during a security sync task. (BAI-16215)
Salesforce 1.7.3.0
System enhancements
Fixed issues
The SalesForce connector was not correctly parsing SOQL queries. (BAI-17061)
Salesforce 1.7.2.0
System enhancements
| Enhancement | Description |
| Support for custom Salesforce login domain | You can now specify a key-value pair for a custom Salesforce domain in the web.config settings for the Salesforce connector. For more information, see How to Set Up and Configure the Salesforce Connector. |
Fixed issues
Salesforce connections with a custom domain login would fail to connect. (BAI-13452)
Crawl times for the Salesforce connector were extremely long. (BAI-15220)
Salesforce 1.0.0.0
System enhancements
Code refactored and optimized.
Added support for new Salesforce attachments.
Fixed issues
Connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) to the WebService URL cannot be established. (BAI-10413)
Connector times out on enumeration. (BAI-11832)
Salesforce has changed the methodology for attachments while maintaining the older attachment methodology. Old attachments are still indexed but new ones are not. (BAI-12119)
