How to Set Up and Configure Facebook Workplace Connector
All BA Insight connectors can be downloaded from the Upland Right Answers Portal under Knowledge > BA Insight > Product Downloads > Connectors. This connector is installed with the same generic steps as any BA Insight connector. You must satisfy the Prerequisites for your connector before installing. The configuration specifics are detailed below.
How to Generate an Access Token
See Facebook Workplace Connector Prerequisites.
How to Configure the Facebook Workplace Connector
| Setting | Description |
Facebook API |
Specify the root URL of Facebook web service API to use. |
Access Token |
Specify the access token for API requests. See "How to Generate an Access Token" above. |
Index docs as items |
Check this option to index the Facebook group’s documents instead of posts. |
| Group filter |
This filter allows you to filter the groups which the "Datastores Load Collects the logical division of your data (data stores) from the source system. Runs on a schedule Logs information according to log level set" task returns. Filter uses group names and is case-sensitive. |
| Index only public groups | Check this option to index only public groups. |
