How to Set Up and Configure Your FileNet API Connector
Configure the Connection
- Go to Connector Framework Console > Connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,).
Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) or Connectivity Hub > Connection tab.
- Select your FileNet connector from the Connection column.
Scroll to the bottom of the Connection Info tab to access additional settings.
| Parameter | Description |
Administrator Account for Content Engine |
Enter the account name in the format used to login to Workplace/WorkplaceXT or the FileNet Enterprise Manager applications.
FileNet Content Engine Web Services URL |
Content Engine Web Service URL
WorkplaceXT URL |
The FileNet Client Web Application URL (Workplace or WorkplaceXT).
Disable Security |
With this check box selected, the Connector does not make security calls and marks all items as public. |
Map "#AUTHENTIFICATED-USERS" FileNet group to corresponding groups from Active Directory A directory service for Windows domain networks. A hierarchical structure that stores information about objects on the network. Used to manage permissions and control access to critical network resources. |
#AUTHENTIFICATED-USERS is an internal reserved group in FileNet that represents an Active Directory as OU (Organization Unit) or a container of all of the users/groups who have access to the FileNet P8 CE (Content Engine).
Example: S-1-5-21-1117143457-322811180-3059026074-80765;S-1-5-21-1117143457-322811180-3059026074-81897;trickydomain\nitor test group1;baitest\Users
Specify Content Filters
Go to the bottom of the Content Info tab and use these steps:
- Object Classes: Use the item picker to select the object classes you want to include in this content index:
Include AllExclude the FollowingInclude Only the FollowingInclude AllExclude the FollowingInclude Only the Following- Custom Filters: Use the supported custom filter types as described below:
ITEMID: Index only the items with the specified ID.
Format:
ITEMID=id1,id2,id3…id(n ). Separate item IDs using a comma (,).
ExampleITEMID=2ed7899a-9d92-416b-85c4-8c2ad0011c3,fd9e4663-4ea5-4086-a4a1-8d545f1031a3,468e5d1f-dbb2-485a-a96b-8e4781d5eab5FOLDER: Index items from the specified path.
Format:
FOLDER=/folder1/folder2/, /folder1/folder3/folder4,…/folder(n)/folder(nn)
Separate paths in the filter using a comma (,). There are two modes for the folder filter:
- Literal path: /Folder1/Folder2/
- Data is retrieved only from the specified path.
- Path template: Folder1/*
- Data is retrieved from the specified path and all of its sub paths.
For example:
FOLDER=/Documents/Technical Notes/,/Reports/Year2013/*ROWLIMIT: Limit returned results.
Format: ROWLIMIT=N: Because the Connector separately retrieves Document and Custom objects, the result will be N*2.
So, ROWLIMIT=10 returns 20 objects where 10 are documents and 10 are custom objects. For example, ROWLIMIT=50.
- Click Save.
