How to Set Up and Configure the IBM Notes Connector
All BA Insight connectors can be downloaded from the Upland Right Answers Portal under Knowledge > BA Insight > Product Downloads > Connectors. This connector is installed with the same generic steps as any BA Insight connector. You must satisfy the Prerequisites for your connector before installing. The configuration specifics are detailed below.
IBM Mailbox (MB) Sub-Connector
Filter Mailbox Items Using the Repository Tab
This section applies only to the IBM Notes Mailbox or "MB" sub-connector. Navigate to the Repository tab to enter this information.
- Load Available: Click to load the list of available IBM Lotus Domino database files.
- Exclude Directories: Use the Connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,).
Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) Information form (previous form) to narrow down the choices.
- Available list: Select the repository of databases and add or remove to or from the Selected list.
The Advanced Security Module is needed for the connector to support both database level and document level permissions.
After you complete the basic settings, scroll down in the Connection Info tab to access additional settings:
| Setting | Description |
| Notes Password | Enter the password of the account running the Notes Connector. |
| Exclude Database Folders |
Enter the folder paths to exclude folders when database names are loaded into the Repository tab.
| Ignore Reader Fields | Click this setting to ignore reader fields when computing ACLs. |
| Use Local Address Books |
Click this setting to use the local address books for the security sync Loads User and Group tables and executes the mapping based on the connector configuration. operation.
To set up the local replica and enable this operation, follow these steps:
| Domino Server | Enter the name of your IBM Lotus Domino server. It must be in the form: <server name>/<instance name> |
Note: If you selected the Mailbox sub-connector, continue your configuration as described in the section above IBM Mailbox (MB) Sub-Connector.
