How to Set Up the Deltek Vision Connector
All BA Insight connectors can be downloaded from Upland Right Answers Portal under Knowledge > BA Insight > Product Downloads > Connectors. This connector is installed with the same generic steps as any BA Insight connector. You must satisfy the Prerequisites for your connector before installing. The configuration specifics are detailed below.
How to Create Custom Stored Procedures
The Deltek Vision Connector uses custom stored procedures. Use the following steps to create these procedures:
- Install the BA Insight Deltek Vision Connector.
- Connect to the Deltek Vision database via SQL Server Management studio as a user with permission to create new stored procedures.
- Go to the SQL Scripts directory located under the installation target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch.
- (A Search application instance has one or more indexes) folder.
- Run the SQL script in
StoredProcedures.sql.
