Troubleshooting OneDrive Connector
The OneDrive Connector has a custom log in the Logs folders under the installation target A Target is a "pointer" to a specific instance of a search application, such as Elasticsearch.
- (A Search application instance has one or more indexes) location.
By default, the logging level is set to
INFO. -
If you want to troubleshoot, set the log level to
DEBUGin the Logging.config file in the installation directory. -
The OneDrive connector does not retrieve 'hidden' properties for the items crawled.
If there are properties which you want to include from this category, they must be listed in web.config under "ListOfHiddenColumnsToInclude".
A complete record of the 'hidden' properties which have been ignored are listed in the connector Logs, when setting the Log Level to DEBUG.
