Troubleshooting Your Yammer Connector
The logging level for the Connector specific logs can be changed from the Logger.config file in the installation folder.
A DEBUG or TRACE level might generate a large number of logs files and should only be used for troubleshooting. When troubleshooting for a specific issue, BA Insight recommends that you use the datastore type filters and group filters.
