Veeva Vault Connector Prerequisites
The Veeva Vault connector enables you to crawl both the full text and metadata Provides context with details such as the source, type, owner, and relationships to other data sets. Metadata provides details around the item being crawled by Connectivity Hub. of Veeva Vault objects, by querying via the API.
| Required Permission | Description |
| Veeva Vault account |
The account used to crawl your data must have full READ permissions to the following content:
The account used to crawl your data must have DOWNLOAD permissions for either or both of the following (depending on business requirements):
The crawl account must have access to a document's full lifecycle to detect all changes to the document.
Note: The API respects user permissions. If a user does not have permission(s) to a document (VIEW, READ, etc.), then the API does not perform the action requested by the user.
| Veeva Vault version |
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | All BA Insight Connectors support fetch ACLs from the source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle.. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework. |
| Required Software | .NET Framework v4.7.2 |
