eVault Connector Prerequisites
Knowledge Requirements
To install the eVault connector you must have knowledge of how to configure and administrate the following applications:- SharePoint or MS Search server
- Symantec Enterprise Vault
DCOM Verification
Verify DCOM is enabled on your eVault Server: Follow these steps to check the DCOM status and to enable DCOM if it is disabled.
- Click Start > Run, type
Dcomcnfg, and click OK. - Go to Component Service > Computers > My Computer.
- Right-click on My Computer and select "Properties."
- Select the Default Properties tab.
- To enable DCOM, select "Enable Distributed COM on this computer."
- Restart the operating system for the change to take effect.
| Required Permission | Description |
| eVault Account | A valid eVault account, including username and password is required. |
| eVault version | ||
| Searchable content types | Yes | All content types. |
| Content Update | Full and Incremental | All BA Insight Connectors support both Full and Incremental crawls, unless noted. |
| Permission Types | Yes | All BA Insight Connectors support fetch ACLs from the source system Your Source System is the repository where your data is stored (data to be indexed). This repository is managed by applications such as: - SharePoint O365 - SharePoint 2013/16/19 - Documentum - File Share - OpenText - Lotus Notes - etc. Your Source System repository can also be a database such as SQL or Oracle.. To make items public or restricted to a single user/set of users, you can do so within the Connector Framework. |
| Required Software |
| You must install the Enterprise search connectors on your SharePoint or MS Search server before you use the Enterprise Vault Connector with SharePoint. This installation step is not required before you install the Enterprise Vault connector on your Vault server (or other API server). Verify DCOM is enabled on your Vault Server. |
