iManage connector release notes
The respective releases of the iManage connector feature the following enhancements. For more information about the connector, see About the iManage connector.
iManage connector 2.1.1.1
System Enhancements
| Feature | Description |
| Support for iManage Security Policy Manager (SPM) policies |
The iManage connector now supports Security Policy Manager (SPM) policies that are applied to documents and workspaces. This allows the your indexed content to maintain and reflect advanced iManage security models for increased accuracy in security enforcement. For more information on SPM policies, see the iManage documentation. |
Fixed issues
The iManage connector now uses enhanced logic to handle throttling for improved performance. (BAI-17795/BAI-17801)
iManage connector 2.1.1.0
System Enhancements
| Configuration enhancements |
The configuration settings for the iManage connector has been updated with following configuration options:
You may experience increased performance when one of these settings is enabled. For more information, see Setup and Configure the iManage Connector. |
| Metadata enhancements | The iManage connector now returns the has_attachment metadata column for emails that have attachments. |
Fixed issues
If you were crawling an iManage Cloud environment and you selected iManage Work API as the API integration, security syncs Loads User and Group tables and executes the mapping based on the connector configuration. would fail. (BAI-16926)
When crawling iManage with the iManage Work API, in some scenarios, security sync tasks would fail when getting the group ID. (BAI-17241)
iManage connector 2.1.0.0
System Enhancements
| Improved crawl performance | The iManage connector has been enhanced to decrease the amount of time needed to crawl your iManage items and the number of items that are crawled per second. |
| Support for iManage Sync API |
The iManage connector now supports the iManage Sync API. This API allows you to crawl more than 10,000 users, groups or group members from your iManage instance. You can select this API when setting up and configuring your iManage connector. |
Fixed issues
To improve the performance of iManage connector crawls, the connector now uses parent folders to return documents rather than the folder path. (BAI-15005)
