How to Install and Configure Haystack
Prerequisites
  • An Elastic Index is required
    • Elastic version: 7.7-7.11 (Download here v7.10.0)
  • Microsoft Visual C++ 2015-2019 installed via Visual Building Tools 2019
    • Windows 10 SDK
    • MSVC - VS 2019 C++
  • Python v3.7.9
  • Torch v1.10.2 - see "Install Torch v1.10.2" below
  • XPDFReader
  • Git
  • Haystack v1.9
Microsoft Visual C++ 2015-2019 using Visual Building Tools 2019
Procedure:
  1. Download Build Tools for Visual Studio 2019
  2. Double click the executable file downloaded.
  3. Wait until the Build Tools is loaded.
  4. Choose Desktop development with C++.
    1. Choose MSVC v.142 – VS 2019 C++ x64/x86 build tools.
    2. Windows 10 SDK
  5. Click Install
  6. Restart the server if a pop-up message is displayed for this.
Install Python v3.7.9
Procedure:
  1. Download Python v3.7.9 from here: https://www.python.org/downloads/release/python-379/
  1. Right-click and select Properties. Unblock the file.
  2. Double-click the executable file downloaded
  3. In Python installation windows, select the check-box “Add Python 3.7 to PATH“
  4. Click Install Now
Install Python Torch v1.10.2
  1. Open a web browser.
  2. Download Torch
    1. "torch-1.10.2+cpu-cp37-cp37m-win_amd64" from here.
    2. Ensure the version of Torch matches your processor architecture – typically, win_amd64.
      1. If your processor architecture is different, search and download from here: https://download.pytorch.org/whl/torch_stable.html
    3. Right-click and select Properties. Unblock the file.
    4. Note where the file is stored.
  3. Open a command prompt with Admin privileges if it is not already open.
  4. Run the following command (alter the file name and path, as necessary):
    Copy
    pip install " C:\Users\admin_account\Downloads\torch-1.10.2+cpu-cp37-cp37m-win_amd64.whl"
Install XPdfReader
Procedure:
  1. Download XpdfReader from here.
  2. Select the version for your operating system (example: Windows 64-bit).
  3. After the executable file is downloaded, double click downloaded file.
  4. Press Next.
  5. Agree the license agreement.
  6. Choose install location and click Install.
Install Git
If you do not have Git installed, use the following procedure to install it.
Procedure:
  1. Download Git from here.
  2. Double-click on the downloaded executable (Example: Git-2.42.0.2-64-bit.exe)
  3. Press Next until you receive the window where you have this message: “Configuring the terminal emulator to use with Git Bash“
  4. Choose “Use Windows default console window“ and continue to click Next until you have the Installation option
  5. Click Install
  6. After the installation is done, you need to configure the system variable.
  7. Right-click on "This PC"
  8. Select Advanced system settings > Environment Variables...
  9. Under System variables, select the "Path" row, click Edit, New, and add two paths:
    • Path to /bin folder from installation location (default: C:\Program Files\Git\mingw64\bin\)
    • Path to the Git command tool
  10. In Environment variable you should have these 2 variables saved.
Install Haystack v1.9.0
Installation steps:
  1. Download Haystack from GIT. Scroll down the page and download the Source Code zip file.
  2. Create a new Haystack folder somewhere in your environment.
  3. Extract the contents of the .zip file to your Haystack folder.
  4. Using the cd command, navigate to the Haystack directory and into the root
    • For example, cd "C:\Haystack\haystack-1.9.0"
  5. Using a text editor, create a text file and copy the content below inside that file:
  6. Save the file with the name requirements.txt and copy the text file to root folder from Haystack folder (step 5)
  7. Open a command prompt with Admin privileges if it is not already open
  8. Using command “cd“, navigate to the Haystack installation directory (step 5).
  9. Run the following command:
    Copy
    pip install -r requirements.txt
  10. Wait until all the requirements are installed.
  11. From the same command prompt window run this command (do not remove the “/“):
    Copy
    pip install rest_api/
  12. Wait until the installation is done.
  13. From the same command prompt window run this command (do not remove the “/“):
    Copy
    pip install ui/
  14. Wait until the installation is done.
Run Haystack
Once all prerequisites are satisfied and all required programs are installed, use the following steps to run Haystack:
  1. Open a command prompt with Admin privileges if it is not already open.
  2. Using “cd“ command, navigate to the Haystack installation directory (where you extracted the .zip file).
    • Example: cd “C:\Haystack\haystack-1.9.0“
  3. Run the command:
    Copy
    uvicorn rest_api.application:app --host 0.0.0.0
  4. If everything is running correctly your command prompt should show something similar to this:
Verify Haystack is Running
To verify Haystack is running, use the following steps:
  1. Open the URL: http://localhost:8000/docs
  2. The Swagger API documentation for Haystack is displayed.
  3. This verifies Haystack is running.
  4. If the Swagger API documentation for Haystack is not displayed:
    1. Verify the command prompt running Haystack is open.
    2. If the command prompt running Haystack is not open, follow the steps in "How to Run Haystack" above.
How to Restart Haystack
  1. Close the current command prompt where Haystack is running and follow the steps in "How to Run Haystack" above.
Possible Errors and Fixes
Error
  • ERROR: Could not find a version that satisfies the requirement canals (from farm-haystack) (from versions: none)
  • ERROR: No matching distribution found for canals (from farm-haystack)
Solution
  • Check the Python version and Pip version.
  • Correct versions:
    • Python v3.7.9
    • Pip version 20.1.1
Error
  • Failed loading pipeline component 'PDF File Converter'.
Solution
  • XpdfReader is not installed.
  • Environment variables for Git are not configured
Error
  • error: Microsoft Visual C++ 14.0 or greater is required. Get it with "Microsoft C++ Build Tools"
Solution
Error
  • Could not build wheels for mmh3 which use PEP 517 and cannot be installed directly
Solution
  • Install Windows 10 SDK.
Error
  • RuntimeError: InitVar is not supported in Python 3.7 as type information is lost
Solution
  • Run the following commands:
    Copy
    pip install Pydantic==1.8.2  /  pip install inflect==5.4.0
Error
  • haystack.errors.PipelineSchemaError: Haystack component with the name 'PDFToTextConverter' not found.
Solution
  • Run the following command:
    Copy
    pip install pytesseract==0.3.7 / pip install wheel==0.37.0
