Zendesk Hub
About Zendesk Hub
To integrate SmartHub with Zendesk you must install the SmartHub for Zendesk app package into your Zendesk tenant.
SmartHub for Zendesk is a Zendesk for Support app.
See more info about types of Zendesk applications here.
Installation Procedure
Perform the following steps to install SmartHub for Zendesk
- Go to your SmartHub install folder.
 - Remove the X-Frame-Options and Content-Security-Policy header from the web.config file.
 - Go to integrations folder.
 - Archive the smarthub_for_zendesk_app folder into a .zip file.
 - Log in to your Zendesk tenant as an Admin.
 - Go to Admin Settings > Manage (under Apps).
 - Click Upload private app.
 - Give the app a name.
- Example: 'SmartHub Search'
 - Choose the .zip file obtained at step 3.
 - Click Upload.
 - Review the settings of the app using the below table.
 - Click Install.
 - Done!
Configuration Options
To change the app settings at any time:
- Go to Admin Settings -> Manage (under Apps)
 - Choose "Change Settings" from the app menu.
 - Modify the app setting(s) detailed below, as you desire.
The following table contains details about what each setting is and how it can be customized.
| Setting name | Usage | Sample/default value |
| Title |
                                                             The title of the app. This is how the app name appears across the Zendesk tenant.  |
                                                        SmartHub Search |
| SmartHub Page Address for Ticket Side Bar | The SmartHub page that will be displayed within the iframe when a ticket is in view. | https://smarthub.contoso.com/Results.html |
| Smart Hub Page Address for Ticket Editor Action Bar | The SmartHub page that will be displayed when you click on the SmartHub app in the Action Bar of a Ticket Editor Text Box. | https://smarthub.contoso.com/Results.html |
| Smart Hub Page Address for Navigation Bar | The SmartHub page that will be displayed full scree when you click on the SmartHub app on the navigation bar on the left. | https://smarthub.contoso.com/Index.html |
| Container height (in pixels) when SmartHub is in Ticket Side Bar | This is the height of the SmartHub iframe container that appears in the Ticket Side Bar. | 600 |
| Container height(in pixels - max 320) when SmartHub is in Ticket Editor Action Bar | This is the height of the SmartHub iframe container that will pop up in the Ticket Editor Action Bar when you click on the SmartHub app. | 320 |
| Container width (in pixels) when SmartHub is in Ticket Editor Action Bar | This is the width of the SmartHub iframe container that will pop up in the Ticket Editor Action Bar when you click on the SmartHub app. | 400 |
