Prerequisites: SmartHub with Amazon Kendra
NOTE! You must install all of the prerequisite applications listed for your SmartHub and search engine instance.
Any issues experienced by BA Insight clients during installation are typically traced to a failure to meet the required prerequisites.
NOTE! If you are integrating BA Insight Smart Previews with SmartHub, SmartHub v6 only supports Smart Previews v3.0 and later.
Installation Prerequisite Checklist
| Prerequisite | Requirement | Description | Completed |
| SmartHub Server: OS |
Operating System | Microsoft Windows Server
| SmartHub Server: Windows Roles/Features | Windows Roles and Features | Must have Web Server(IIS) role enabled with the following Roles and Features selected:
| SmartHub Server: .NET Framework | .NET Framework |
| Accounts: Service |
Service Account (domain\user) |
Local or network service account used to run the SmartHub Application pool in IIS
Account credentials: (domain\user) |
| Accounts: Install |
Installation Account (domain\user) |
Account used to install SmartHub
| Supported Web Browsers
*Unsupported Web Browsers Other web browsers may work with SmartHub, but are not officially supported by BA Insight, such as:
Browsers that are in incognito mode are not supported. |
| Analytics: Elasticsearch Index |
Elasticsearch v7.10-8.x |
Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance used for the search index (search engine).
Java: The SmartHub Analytics component requires Elasticsearch Java JDK. Elasticsearch v7.x and later bundles Java with the software (OpenJDK). A separate Java download/install is NOT required. For more information see Elasticsearch documentation.
Elasticsearch URL: Elasticsearch Username: Elasticsearch Password: |
| Analytics: Kibana | Kibana (same version as Elasticsearch above) |
Kibana URL: Kibana Username: Kibana Password: |
| Haystack (Optional) | Haystack Service is required for the Questions and Answers feature. |
We recommend Haystack be deployed to a separate server/resource so SmartHub performance is not negatively impacted.
| NLQ Services (Optional) |
Only one NLQ service should be configured. Supported NLQ/AI Engines:
For more information see: |
Service Endpoint:
Service Key (LUIS only): |
| Search Engine
Amazon Kendra |
Limitations
For details see the Limitations section from Connect SmartHub to the Amazon Kendra Backend. |
Kendra index name: Kendra access key: Kendra secret key: Kendra region: Click here for more details |
Network Requirements: DNS |
DNS entry for SmartHub site |
DNS name / URL for SmartHub: |
| Network Requirements: SSL Cert | SSL Certificate |
Certificate name: Pass-phrase (if required): |
| Network Requirements: Internal |
Internal Network Connectivity |
The SmartHub server must have network connectivity to the following:
Verified:
| Network Requirements: External | External Network Connectivity | Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
