Secure Your Content Using the Advanced Security Module
Security trimming requires that you setup the ACL properties for your connector.
About
  • ASM = Advanced Security Module
  • ASM is used by:
    • SmartHub
    • Connectivity Hub
  • For a video walk-thru of the ASM see BA Insight ASM walk-thru.
Overview
For a high-level conceptual explanation of the Advanced Security Module, with graphics, see Security Trimming in SmartHub and Connectivity Hub.
Configuration Options
Any combination of the following authentication modes are valid:
  • SmartHub Authentication Modes:
    • Azure AD
    • Windows authentication
  • Connectivity Hub Target Directories:
    • Azure AD
    • Active Directory
      • Must be on-premise AD if you use a connector with no security sync, such as FileShare
Configuration Examples
Option 1: Azure AD in SmartHub and Connectivity Hub
Option 2: Azure AD in SmartHub/Local AD in Connectivity Hub
Option 3: Windows Authentication in SmartHub*/Local AD in Connectivity Hub
Option 4: Windows Authentication in SmartHub*/Azure AD in Connectivity Hub
ASM User Format, Based on Connectivity Hub Target Directory
Azure AD Target Directory
  • UPN:
    • user@domain
    • domain\user: Somesite.local\a_sharepoint_user
  • ID: ########-####-####-####-############
Active Directory Target Directory
  • Distinguished name:
    • full_domain\user
  • UPN: user@full_domain
  • SID: S-1-5-32-573
To find out the user format, check the SmartHub log for these entries and make sure the requirements listed above are met:
DEBUG - GetGroupInfo Started
DEBUG - User: a_sharepoint_user@azuredomain.com
DEBUG - Complete list of users, including domain remapping
DEBUG - Remapped user: a_sharepoint_user@azuredomain.com
DEBUG - Remapped user: a_sharepoint_user@localdomain.local
DEBUG - Retrieving Security Map
DEBUG - GetGroupsList Started
Add the Advanced Security Module Tuning Stage
To use the Advanced Security Module, you must add a Tuning stage.
Use the following steps to add the ASM Tuning stage.
Caution: This stage must be the first stage executed among your search engine tuning stages.
  • You can change the order of the stages by using the up and down arrows.
Applies to content secured with Active Directory users and groups:
  • If you're using Advanced Security Module to secure content from a Connector which relies on Active Directory for users and groups, such as (FileShare, FileNet, SharePoint), you must set "enableSidSecurity" to "true".
  • See more details in the configuration table below.
  1. Navigate to the SmartHub Administration page at http(s)://[web-app-url]/_admin.
    • For example: http://smarthub.azurewebsites.net/_admin
  2. Click on the search engine which should be secured.
  3. Click ADD QUERY TUNING.
  4. User Experience Tuning: Use the down arrow to select Advanced Security Module.
  5. Name: Complete a name for your stage.
  6. Parameters: Copy and paste the following code, replacing the sample values with the appropriate values.
    Copy
    <config>
        <userPrincipalNameProperty>upn</userPrincipalNameProperty>
        <domainRemapping>domain=domain.local</domainRemapping>
        <groupCacheTimeout>10</groupCacheTimeout>
        <additionalSecurityLevels>0</additionalSecurityLevels>
        <enableSidSecurity>true</enableSidSecurity>
        <includeResultSources>ASM</includeResultSources>
        <excludeResultSources>XYZ</excludeResultSources>
        <impersonateUser>domain\uA=domain\uB</impersonateUser>
        <debug>false</debug>
        <showErrorWhenCHNotAvailable>true</showErrorWhenCHNotAvailable>
    </config>
Parameter
Required
Description and Value
(optional)
  • Values
    • The default value is 0
    • The maximum value is 10
  • For BA Insight Connectors that use multilevel security, the value should be greater than 0.
  • Connectivity Hub calculates this value automatically, but you can override this value by specifying a new value.
  • Increase this value if items that are secured with multiple levels are returned incorrectly in the search results.
  • The higher the value, the slower the query.
debug
(optional)
  • The default value is false
  • Specify an internal parameter that is used for advanced troubleshooting.
domainRemapping
(optional)
  • The default value is an empty string (no domain remapping).
  • Use this parameter to remap the possible combinations of user login domains to the BA Insight Connectors mapped domains, such as:
    • SourceDomain1=TargetDomain1&SourceDomain2=TargetDomain2&…
  • The user from the source domain is treated as if this user was one of the users for from target domain.
    • For example: domain=domain.local&corp=corp.local
enableSidSecurity
(optional)
  • Default value is false
  • Set this parameter to trueif the source systems rely on Active Directory for both its users and groups, such as FileNet and FileShare.
  • This setting also implements multilevel security:
    • For example, multilevel security is implemented for a FileNet source system using the marking sets capability.
(optional)
  • Default value is an empty string (in other words, no source is excluded)
  • Specify a list of result sources for which the security transformation is not applied. Use this list when you want to apply security on all but some specific sources.
  • Specify your values using a semicolon-separated (;) list of names.
    • For example: Local SharePoint Sites;CustomSource
groupCacheTimeout
(optional)
  • Default value is 5 minutes.
  • Specify the time in minutes for the group cache expiration time.
impersonateUser
(optional)
  • Default value is an empty string (in other words, no impersonation).
  • Enter the domain and user name of a user that you want to impersonate in the search results.
  • This parameter can contain a string with one user specified using the following format: domain\user
  • Alternatively, specify the user mapping string using the following format:
    • SourceDomain1\SourceUser1=TargetDomain1\TargetUser1;SourceDomain2\SourceUser2=TargetDomain2\TargetUser2;
In the first example, the security level for this user is applied to all users.
  • This specification overrides the current user security level so that all users have the same access as this user.
  • In the second case, if mapping is found for the user under which the request is performed, the target user security is applied.
(optional)
  • Default value is *  (in other words, all sources are processed).
  • Specify a list of result source names for which this stage transforms the query.
  • This parameter must include all the result sources returning results from content sources that are secured using the native security model. Specify your values using a semicolon-separated (;) list of names.
showErrorWhenCHNotAvailable X
  • Default value is true
  • Controls whether an error is displayed if BA insight Connectivity Hub is unavailable
userPrincipalNameProperty (optional)
  • Default value is an empty string (uses the UPN property).
  • This property reads the user name for the current user from the token.
  • If SmartHub is configured to use Azure AD Authentication and you want to pass the onpremise sid for security validation, then specify the onprem_sid value for userPrincipalNameProperty
    • <userPrincipalNameProperty>onprem_sid</userPrincipalNameProperty>
Note: Security validation using SID is supported
