Microsoft Search Calendar
About
Microsoft Search Events search engine uses the Graph API to:
- Search for events in a user’s primary calendar
Set Azure Active Directory Authentication
Set authentication to Azure Active Directory in SmartHub as described here: Azure Active Directory Authentication.
Client ID Requirements
Additionally, the Client ID specified in Azure Active Directory Authentication, must belong to an application with the following permissions:
- Microsoft Graph
- Calendar.Read
How to Add the Microsoft Search Events Backend to SmartHub
Use the following instructions to add the Microsoft Search Events backend to SmartHub:
- Navigate to the SmartHub Administration page: http(s)://[web-app-url]/_admin
 - Click Add New Search Engine. The search engine dialogue box appears.
 - Type: Select Regular.
 - Search Engine: Select MS Search Calendar from the drop-down list.
 - Name: Enter a name for your search engine.
 - Graph URL: Enter the Graph URL. For example, https://graph.microsoft.com.
 - Authentication: Select whether to enable or disable Impersonate authentication:
- Impersonate - true
- Security trims the results using the current user running the search
 - Impersonate - false
- Client Id: Enter the Application ID from Azure App Registrations.
 - Client Secret: Enter the Key's value from Azure App Registrations.
 - Microsoft Login Endpoint: example: https://login.microsoftonline.com
 - Access Token: Enter the access token from SmartHub's OAuth page.
 - Refresh Token: Enter the refresh token from SmartHub's OAuth page.
8. ClickOK.
If you use SmartHub with Azure Active Directory authentication, you can reuse the same App and jump to step 5.
- Navigate to portal.azure.comand log in.
 - From the left side menu go toAzure Active Directory → App registrations → New registration
- Name: Enter the name of the application.
 - Application type: Select Web app / API.
 - Sign-on URL:Enter the SmartHub's URL.
 - Select API Permissions to open the settings menu panel.
 - Click Add a Permission.
 - Select APIs my organization uses and add the following permissions (as you type the name, it appears):
- Microsoft Graph
- Calendars.Read
 - Calendars.Read
 - Microsoft Graph
 - Click Certificates & secrets > New client secret to generate a client secret key.
 - In the window that appears, enter the following information:
- Description: Enter a name for the client secret. (Note: The nameisyour client secret).
 - Expires:: Select the period until expires.
 - A Value is generated after you clickAdd.
Metadata
The following metadata is available for your results:
- rank
 - summary
 - @odata.type
 - hasAttachments
 - isAllDay
 - sensitivity
 - subject
 - type
 - end
 - start
Limitations
Note the following limitations when using the Microsoft Search Calendar search engine:
Refiners are not supported.
