Prerequisites: SmartHub with SharePoint Online
Deployment Topology
The following is an example of SmartHub as it lives within a network topology.
Installation Prerequisite Checklist
| Prerequisites | Requirement | Description | Completed |
SmartHub Server: OS |
Operating System | Microsoft Windows Server
| SmartHub Server: Windows Roles/Features | Windows Roles and Features | Must have Web Server(IIS) role enabled with the following Roles selected:
| SmartHub Server: .NET Framework | .NET Framework |
| Accounts: Service | Service Account (domain\user) |
Account credentials: (domain\user) |
| Accounts: Installation | Installation Account (domain\user) |
| Supported Web Browsers
*Unsupported Web Browsers Other web browsers may work with SmartHub, but are not officially supported by BA Insight, such as:
Browsers that are in incognito mode are not supported. |
Analytics: Elasticsearch Index |
Elasticsearch 8.1.2 |
Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance use for the search index (backend).
Elasticsearch URL: Elasticsearch Username: Elasticsearch Password: |
| Analytics: Kibana | Kibana 8.1.2 |
Kibana URL: Kibana Username: Kibana Password: |
| Haystack Service (Optional) | Haystack Service is required for the Questions and Answers feature. |
We recommend Haystack be deployed to a separate server/resource so SmartHub performance is not negatively impacted.
NLQ Services (Optional) |
Only one NLQ service should be configured. Supported NLQ/AI Engines:
For more information see: |
Service Endpoint:
Service Key (LUIS only): |
| Search Engine
SharePoint Online |
SmartHub supports SharePoint Online as a search index. |
SharePoint Online URL: SharePoint Online Username: SharePoint Online Password: |
Network Requirements: DNS |
DNS entry for SmartHub site |
DNS name / URL for SmartHub: |
| Network Requirements: SSL Cert | SSL Certificate | If running SmartHub over SSL (recommended), a signed SSL certificate for that DNS name (or appropriate wildcard cert) is required. |
Certificate name: Passphrase (if required): |
| Network Requirements: Internal |
Internal Network Connectivity |
The SmartHub server must have network connectivity to the following:
Verified:
| Network Requirements: External | External Network Connectivity | Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
