How to Run Raw Queries in Elastic
To run raw queries in Elastic backend, you use an Scripting stage. Scripting stages must be added after the Elastic Translator stage in list of Query Tuning stages.
Script example
Copy
if(Query.ExtendedProperties != null && Query.ExtendedProperties.Count > 0 && Query.ExtendedProperties["ElasticSearchRequest"] != null){
    var searchRequest = ((ElasticSearchRequest)Query.ExtendedProperties["ElasticSearchRequest"]);
    searchRequest.UseRawJson = true;
    var requestObject = JObject.Parse(searchRequest.RawRequestJson);
    requestObject["query"] = JObject.Parse("{\"bool\":{\"must\":[{\"function_score\":{\"query\":{\"knn\":{\"escbase_fulltextcontent_vect\":{\"vector\": \"query_embeddings.tolist()\",\"k\": 1000}}},\"weight\": 0.6}}]}}");
    searchRequest.RawRequestJson =  JsonConvert.SerializeObject(requestObject);
For above script to works, you have to add:
References Assemblies:
  • BAInsight.Elasticsearch;
  • Newtonsoft.Json;
Imported Namespaces:
  • Newtonsoft.Json;
  • Newtonsoft.Json.Linq;
  • BAInsight.Elasticsearch.Models;
In order to change elastic query you have to set the value of UseRawJson to true from ExtendedProperties of Queries (line 3). Using requestObject (line 6), we can change the content of query with any custom raw query.
