Install Outlook Message Extension
Overview
Outlook Message Extension provides two functionalities:
Inserts SmartHub search results into mails.
Opens full page SmartHub into Outlook without opening a new tab.
Prerequisites
Outlook message extension it's closely related to .
the message extension from Teams can be moved to Outlook trough following steps.
Perform a installation.
The Teams Hub installation must be successful.
Performing the following steps will not disable or harm Teams Hub.
Steps to install Outlook Message Extension
Open manifest.json and replace
$schemaandmanifestVersionwith:"$schema": "https://raw.githubusercontent.com/OfficeDev/microsoft-teams-app-schema/preview/DevPreview/MicrosoftTeams.schema.json",
"manifestVersion" : "m365DevPreview", -
Open Microsoft Azure and search for your newly created Azure Bot.
From left pane, select Channels and add a new Outlook channel.
Open your Microsoft App Registration related to bot. (Configuration → Click on Manage from the right of Microsoft App ID).
From left pane, select Expose an API and add following Microsoft Client ID Applications:
Outlook desktop: d3590ed6-52b3-4102-aeff-aad2292ab01c
Outlook Web Access: 00000002-0000-0ff1-ce00-000000000000
Outlook Web Access: bc59ab01-8403-45c6-8796-ac3ef710b3e3
Reinstall your updated messaging extension in Teams.
How to Uninstall Outlook Message Extension
Since Outlook Message Extension is tightly coupled to Teams Hub, removing the Teams Hub removes both integrations.
