View Numeric Query Results in a Chart View
About
  • The ChartView component is used to display SmartHub results as a chart.
  • See the image below.
How to Activate ChartView
UI Editor
The easiest and fastest way to work with the Ribbon component is via the SmartHub UI Editor.
Info: For information about how to access the UI Editor as well as who can access it, see How to Use the UI Editor.
  1. Log in to the SmartHub Administration page as an admin.
  2. Click the UI Editor link from the left-side navigation.
  3. Click the Select a page link from the top menu.
  4. Select (double-click) a custom Results.html page to modify it.
    1. BA Insight recommends you create your own custom page (within its own folder) to modify. Leave the default files as templates.
  5. Click the Advanced link at the top right of the window to enter Advanced mode.
  6. Select the Advanced settings edit link at the top center of the page.
  7. Go to the custom settings for the ContentContainer that you wish to render as a ChartView. This is where you will insert your ChartView settings.
  8. To access the available ChartView settings, click the See Default Settings link in the top right corner.
    1. A new browser tab opens with all available SmartHub module settings.
    2. Search for the word "ChartView" on the page to quickly navigate to the ChartView default settings:
      1. By default, ChartView is disabled
      2. The value "Enabled" is set to "false"
        SH.ChartView = SH.ChartView || {};
        SH.ChartView.DefaultSettings = {
            Enabled: false,
            "Chart1": {
                legend: {
                    visible: true,
                    /* #= category # represents the categoryField and  #= value #" represents field from series definition*/
                    template: "#= category #",
                    position: "bottom"
                seriesDefaults: {
                    labels: {
                        visible: true,
                        position: "center",
                        background: "transparent",
                        template: "#= category #: #= value #",
                seriesColors: ["#C5652C", "#FFA338", "#3eaee2", "#FFE198", "#9BC3A3"],
                series: [
                        type: "pie",
                        startAngle: 150,
                        /* this should be a numeric field as it represents the chart value */
                        field: "Rank",
                        /*this represents the chart label value*/
                        categoryField: "title"
                tooltip: {
                    visible: true,
  9. Copy all of code from this view.
  10. Past the code into the open settings file in the Advanced settings editor in your previous browser tab.
  11. Modify the code as you desire:
    • Change the value of Enabled to true
    • Change SH.ChartView.DefaultSettings = { to SH.ChartView.CustomSettings = {
    • Change Chart1 to the name of the content container that is used to display results. By default, this is MainResults.
    • MainResults is the ContentContainer that's in the middle of the HTML page and is responsible for displaying query results
    • Change (add if missing) the attribute DefferredRendering to true.
  12. When you are done, click Save changes at the bottom of the screen.
Note: ChartView will change the display template for a specified ContentContainer.
  • Ensure the ContentContainer is configured to show on the page.
ChartView Settings Example
  • Use the ChartView code below, which contains two charts, "Chart1" and "Chart2," as an example.
    Enabled: true,
    "Chart1": {
        chartArea: {
            margin: {
                left:5,
                right:5,
                bottom:15
        legend: {
            visible: true,
            position: "bottom"
        seriesDefaults: {
            labels: {
                visible: false,
                position: "center",
        series: [
            type: "pie",
            startAngle: 150,
            field: "Rank",
        tooltip: {
            visible: true,
    "Chart2": {
        chartArea: {
            margin: {
                left: 5,
                right: 5,
                bottom: 15
        legend: {
            visible: true,
            position: "bottom"
        seriesDefaults: {
            labels: {
                visible: false,
                position: "insideBase",
        series: [
                type: "column",
                field: "Rank",
                categoryField: "title",
                color:"#192930"
                type: "column",
                field: "Rank",
                color: "#33606B"
        ], categoryAxis: {
            axisCrossingValue: [0, 5],
            minorGridLines: {
                visible: true
            majorGridLines: {
                visible: true
        valueAxis: [
                title: {
                    text: "Rank"
                majorUnit: 10,
                line: {
                    visible: true
        tooltip: {
            visible: true,
            template: "#= category #: #= value #"        }
SH.ChartView.PathsToExclude = [];
Note: The ChartView settings are built on the KendoChart settings.
