Azure Storage with TLS
.NET v4.7.2 is required by all BA Insight applications.
Check the Prerequisites topic of your BA Insight application to verify you have satisfied requirements before proceeding.
To use an Azure storage account with TLS you must enable different TLS versions (such as 1.2) via registry as detailed by Microsoft here.
If the registry modification is not made, errors can occur.
